Debug Error
msaadatpour
Dear Admin
I am going to compile a program codeing of software. All the files are in the subroutine and/or function format. I've written a main program to eliminate the linking error as "error LNK2019: unresolved external symbol _MAIN__ referenced in function _main". The initiatesoftware run commands are included in the function entiteled CE_QUAL_W2 as below
INTEGER(4) FUNCTION CE_QUAL_W2 (DLG)
! CVF specific code
USE DFLOGM; USE MSCLIB; USE DFWIN, RENAMED => DLT;
!DEC$ATTRIBUTES STDCALL :: ce_qual_w2
!DEC$ATTRIBUTES REFERENCE :: Dlg
USE IFPORT ! to get current working directory
USE MAIN
USE GLOBAL; USE NAMESC; USE GEOMC; USE LOGICC; USE PREC; USE SURFHE; USE KINETIC; USE SHADEC; USE EDDY
USE STRUCTURES; USE TRANS; USE TVDC; USE SELWC; USE GDAYC; USE SCREENC; USE TDGAS; USE RSTART
use macrophytec; use porosityc; use zooplanktonc !v3.5
include "omp_lib.h" ! OPENMP directive to adjust the # of processors
EXTERNAL RESTART_OUTPUT
TYPE (DIALOG) :: DLG
INTEGER :: RESULT
END FUNCTION CE_QUAL_W2
I've added the main program as below
program waterqualities
USE MAIN
TYPE (DIALOG) :: DDLG
RunsRes=CE_QUAL_W2 (DDLG)
end program waterqualities
I have the error message as "error LNK2019: unresolved external symbol _CE_QUAL_W2 referenced in function _MAIN__". Would you please help me. I've attached the files.
Bests
M. Saadatpour
anthonyrichards
New Contributor III
Add an Interface block for your function to your main program that calls it (or put it in a module and then USE the module in your main program and anywhere else that you reference the function).
INTERFACE
USE DFLOGM
END FUNCTION
END INTERFACE
so that the compiler knows what to look for.
Ensure that your function definition code is included in your project.
msaadatpour
Thanks alot.
