29655 Discussions
forrtl: severe (157): Program Exception - access violation
msaadatpour
I've added a main procedure to the source code of progam to run the software more and more. In Debug mode the program is excuted and I would be able to run the program. But when I change the running mode to "release", the program would be compiled successfully but when I debug the program there are the message "Unhandled exception at 0x0056da02 in HydrodynaicCali.exe: 0xC0000005: Access violation reading location 0xffffffff" and/ or "forrtl: severe (157): Program Exception - access violation". I've changed some project properties for example Floating Point and Diagnosis, but there were no changes. What should do I? This problem is due to software or hardwareinconsistency?
All the Bests
M. Saadatpour
mecej4
A number of different types of programming errors can result in a crash reported as an access violation. More infrequently, compiler bugs can also cause the same symptom.
The program reported the IP (instruction pointer) value (0x0056da02) at the point where the access violation occurred. You can consult the link map, if one was generated, or using Dumpbin.exe on the program, if no map was generated, to locate the function in which the crash occurred.
You may also try recompiling with the same options as in the "release" mode, but with traceback enabled. Be prepared, however, for the error to go underground or appear somewhere else when compiler options are changed.
Bugs that cause program crashes are more "user friendly" than bugs that skew the program output so slightly as to make the results appear reasonable, hard as it may be to accept this property of programs!
