Debug Mixed Language
Mark_Brown
I have s VS2008 solution.  It has an IVF DLL and a VB.NET Main program.
The VB uses the DLL with
   Private Declare Sub INIT_PARMS Lib "ERI_TEST.dll" Alias "INIT_PARMS" ()
How do I set VS to use the loaded IVF Fortran project vs the compiled DLL so I can single step through the DLL?
To enable debugging of Fortran code called from Visual Basic, right click on the VB project and then select Properties. In the left column, select Configuration Properties > Debugging. Check the box labeled "Enable unmanaged code debugging" and click OK.
Mark_Brown
Thanks for the help. That works perfect.
