29285 Discussions
Debug build goes straight to linker and fails
nvaneck
I edited a few routines, and now when I build, rebuild, clean and rebuild, empty the debug directory in debug 32bit it starts the linker and complains:
Compiling resources... Rc /fo "Debug/Osir.res" "D:\Projects\MicrOsiris\INCLUDE\Osir.rc" Microsoft (R) Windows (R) Resource Compiler Version 6.1.7600.16385 Copyright (C) Microsoft Corporation. All rights reserved. Linking... Link /OUT:"Debug/MicrOsiris.exe" /VERSION:19 /INCREMENTAL:NO /NOLOGO /MANIFEST:NO /DEBUG /PDB:"Debug/MicrOsiris.pdb" /SUBSYSTEM:WINDOWS /OPT:REF /IMPLIB:"D:\Projects\MicrOsiris\Debug\MicrOsiris.lib" mkl_lapack95.lib mkl_intel_c.lib mkl_sequential.lib mkl_core.lib "Debug/Osir.res" Link: executing 'link' LINK : warning LNK4068: /MACHINE not specified; defaulting to X86 LINK : error LNK2001: unresolved external symbol _WinMainCRTStartup Debug/MicrOsiris.exe : fatal error LNK1120: 1 unresolved externals MicrOsiris - 2 error(s), 1 warning(s)
Everything works fine for relase mode in 32bit, relaease mode in 64bit, and debug in 64 bit mode.  Indivdual files compile ofin all modes.
I changed nothing in project properties.  What happend, and how can I fix it?
SergeyKostrov
Valued Contributor II
>>...I changed nothing in project properties. What happend, and how can I fix it? Could you provide *.sln and *.vfproj files of the project for review? It is Not clear what is going on and it looks like simple project configuration issue.
nvaneck
Thanks! In looking to upload those files, I noticed an extra file decided to close and open the solution, and the problem went away.  Something must have been corrupted.... Should have tried that first...
