Debug question
dondilworth
New Contributor II
When my program encounters an array index that is out of bounds, I want to see where in the code it happens. The debugger stops execution, but the call stack has only Windows routines, not my own subroutines. How can I get it to point to the error in my Fortran code?
Anonymous66
Valued Contributor I
To see where the error is occurring in your code, the option /traceback needs to be set. If you are using Visual Studio, it is under properties > Run-time > Generate Traceback Information. It is on by default in debug mode.
Annalee
Intel Developer Support
Anonymous66
Annalee
