29380 Discussions
Getting the path of the used libraries
dnoack
when I compile and link a program with libraries without the -L option using only e.g.
ifort ... -llapack ...
I wonder which lapack library is used by default. Is there a compiler-option available, that outputs the full path of the used libraries? In LD_LIBRARY_PATH there is no lapack available.
dnoack
TimP
You're correct, there is no separate liblapack in MKL, so that library is likely to come from your OS installation, and is likely to be intended for gfortran. You could set ifort -# option to see a full echo of what happens at link time, or use ldd to see which .so libraries your executable uses.
