Debug : watch variables
Hyungjun_K_
I'm using Intel Parallel Studio 2015 Composer Edition.
When debugging, some variables in other module is need to watch but not seen.
The way I use is
module name::variable name
Then, I can see those variables in breakpoint.
Is there any other way or compile option to show all variables defined in other module??
If the variable is used in the current scope, you shouldn't need that syntax, but otherwise you do.
