Hi
In the snippet below, the modules basic and derived are not used at all. The compilation is successful; however when stepped in subroutine Technique, the values of Y (and F after allocation) appear "corrutped" in the debugger. {I get Y(1) = 5.6e-45, Y(2) = NaN,a nd Y(3) = 1.5E-33 instead of -1.0. The the print-out of Y shows its correct value (=-1.0).
However, if the modules basic and derived are commented out then the values displayed in the debugger are correct.
Abhi
Module Basic
Implicit None
Type, Abstract :: Parent
Integer :: i
Real :: r
Contains
Procedure(Scheme), Deferred :: Method
End Type Parent
Abstract Interface
Subroutine Scheme(Object, t, S, F)
Import
Class(Parent) :: Object
Real, Intent(IN) :: t
Real, Intent(IN) :: S(:)
Real, Intent(OUT) :: F(:)
End Subroutine Scheme
End Interface
End Module Basic
Module Derived
Use Basic
Implicit None
Type, Extends(Parent) :: Child
Logical :: Something
Procedure(Method), Pointer, Pass(Object) :: Formula
Contains
Procedure, Pass(Object) :: Method
End Type Child
Contains
Subroutine Method(Object, t, S, F)
Implicit None
Class(Child) :: Object
F = -1.0d0
End Subroutine Method
End Module Derived
Module Collection
Implicit None
Contains
Subroutine Technique(t, Y, tout)
Implicit None
Real, Intent(INOUT) :: t, Y(:)
Real, Intent(IN) :: tout
Real, Allocatable :: F(:)
Integer :: ial
Allocate(F(size(Y)), stat=ial)
print *, Y ! break-point at this line => debugger shows corrupted Y (and F)
End Subroutine Technique
End Module Collection
Program Test
Use Collection
Implicit None
Real :: t, tout
Real :: Y(3)
t = 0.0
Y = -1.0
tout = 1.0
Call Technique(t, Y, tout)
End Program Test
Abhi
Module Basic
Implicit None
Integer :: i
Real :: r
Contains
End Type Parent
Abstract Interface
Import
End Interface
End Module Basic
Module Derived
Use Basic
Implicit None
Contains
End Type Child
Contains
Implicit None
F = -1.0d0
End Module Derived
Module Collection
Implicit None
Contains
Implicit None
Integer :: ial
Program Test
Use Collection
Implicit None
Real :: t, tout
Real :: Y(3)
t = 0.0
Y = -1.0
tout = 1.0
End Program Test
Just prior to Call Technique(t, Y, tout) write the size(Y), and value of t, Y, tout
Just inside Technique, prior to allocation, do the same,
Just after allocation write the value of ial
Then write the size(Y), and value of t, Y, tout
Does anything unusual happen? If so, what?
Jim Dempsey
Hi Jim
I don't think anything unusual happened when I put in those write statements. The printed values are 3, 0.0000000E+00, and 1.000000 for Size(Y), t, and tout. Value of Y is also printed correctly to be -1.000000.
The end result i.e. debugger showing garbage values, happens if:
(1) If I create a new allocatable array Z and pass it instead of Y,
(2) If I pass the dimension N of array (=3) through the subroutine's interface
(3) Create both Y and Z but pass Y (along with the dimension).
and a few other simple variations. In each cases I see garbage values in the debugger albeit they are different.
In case (3) above, Z looks corrupted at the poitn before the call is made while inside Technique Y's first two values are correct but third is garbage.
I am using compiler version 11.1.051 with VS2005 on WinXP64 and I am building a Win32 binary in debug mode.
I tried this snippet with 11.1.046. It shows the same weird behvior; however 11.1.038 works fine. Hope this helps.
Abhi
Abhi
This indicates the code is correct, but the debug symbol definition for Y is incorrect. It probably generated Y as being the address of the first cell of a rank-1 array as opposed to being the address of an array descriptor to a rank 1 array.
Your sample code should be a reproducible test case for Intel to use. Have you sent this to Intel Premier Support?
Jim
I believe that Intel will pick it up from here and assign a reference.
Abhi
Abhi
Issue ID is DPD200142458. The correct behavior mostly returns if you move the unused modules to a separate source file (and compile them there). However, even with this, Y shows up oddly in the debugger inside subroutine Technique - it looks ok in a tooltip, but not in a Watch or Locals window.
I expect the fix for this to appear in 11.1 Update 5, scheduled for mid-February.
Actually, 11.1 Update 6, available now.
