Debugger is unstable ?
WSinc
and then it says "recommend you close all files and restart."
why didn't they test this?
Are we supposed to be testing this stuff for them ?
Kevin_D_Intel
From your other issue I see your current combination is PSXE 2017 with VS 2013 which is a supported and tested combination. If you are experiencing the error repeatedly and can create a reproducing test case then we can pass it to our Debugger development team for further investigation.
