Debugger problem?
Anonymous53
Hi all-
I'm using IVF9.0 in Visual Studio trying to debug a piece of code. Using Ctrl+F5, the code works fine. However, when I tried to execute the codeline by line.The debugger failed to step into a function when it is called. Insteadthe debuggerappreaed to be lost and doing nothing. PressingF5 at the time may help the debugger get back on track. But it generates an error when Visual Studio is closed.
I trid to remove the unrelated statements and to create a simple replica. But the debugger works fine with the simplified version. It seems very hard to replicate the problem.
Very frustrating. Anyone had similar experience?
X
Well, if you really are using 9.0,that's a pretty old version at this point - can you try it with 9.1.034? We have made many improvements over the past year.
