Undefined Address in Watch Window
lou-muccioli
I have the following two simple programs and I'm trying to debug on EM64T using Visual Studio 2005 SP1 and IVF 9.1 Build 20070109 (9.1.034 download) and I'm targeting for x64. In the First program when I step into the charsub routine, the VS 2005 debugger jumps to the end statement and the variable "string" is display has having a value of "undefined address". In the second program when I step into the sub1 routine, the debugger is on the correct line but after the "DO" loop the all locations in the "tmp2" variable show has having "undefined address". I submitted both of these bugs to Premier Support and they WERE fixed but that was prior to me installing SP1 for VS 2005. I have the projects for both programs if you would like to have them.
PS: pasting doesn't seek to work here so I will attached the two problems.
Lou Muccioli
ANSYS, Inc.
Please submit a new Premier Support issue and report this.
lou-muccioli
Will do, I'm waiting to hear back from my Intel contact, Kevin Davis. I wanted to make sure he verified my findings first in case I have some VS/IVF configuration problem...but I don't think I do since I've reproduced this on three different machines.
Lou
