Debugger stopps in open statement
Thomas_S_2
I use Intel Fortran in VS 2010. When trying to debug a simple project the debugger stopps when entering an open statement. The message appears:
xxx.exe caused a breakpoint
stop/contiune
if I press continue the following appears
"Rubeam.exe": "C:\Windows\SysWOW64\sechost.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\rpcrt4.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\sspicli.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\cryptbase.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Program Files (x86)\F-Secure\HIPS\fshook32.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\psapi.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\user32.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\gdi32.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\lpk.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\usp10.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\imm32.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\msctf.dll" geladen, Cannot find or open the PDB file
"Rubeam.exe": "C:\Windows\SysWOW64\dbghelp.dll" geladen, Cannot find or open the PDB file
Rubeam.exe hat einen Haltepunkt ausgelöst.
Das Programm "[5824] Rubeam.exe: Systemeigen" wurde mit Code 29 (0x1d) beendet.
Some one out there having the same problem?
Help heavily appreciated
Look in another window, probably hidden behind the Visual Studio window, for the real error message, which will be "File not found". All of the text you mention appearing after you click Continue is informational and can be ignored.
andrew_4619
Why not add IOSTAT=i-var to the open statement and then you can evaluate the i-var variable (or whatever you choose to call it) for the error code. Posting a code fragment might for the error be helpful also....
mecej4
If you look at the list of error codes in the Intel Fortran documentation, you will find that Error 29 signifies "file not found". Find the correct path to the file and make sure that the program attempts to open the file in the directory where the file is located. You may either enter the full pathname of the file in the OPEN statement or set the correct working directory before running the program. The Fortran INQUIRE statement is also available to help with problems such as this.
Thomas_S_2
I got it! Thanks for the quick response!!
