29386 Discussions
Debugger warning "unable to determine length of string variable" - unhelpful !
john_e
The essentials:
Package ID: l_fc_c_9.1.041
Package ID: l_cc_c_9.1.047
I have program compiled with these options:
-auto -ip -mp -fpstkchk -traceback -fpe0 -g -ftrapuv -warn all -warn nounused -gen-interfaces -check "bounds,format,output_conversion,uninit,arg_temp_created"
( yup I'm trying to resolve some bugs )
The program compiles fine with no warnings during the compile.
However fails in execution. When loading into the debugger I get this:
> idb -gdb prog.x
Intel Debugger for applications running on IA-32, Version 9.1-27, Build 20070202
object file name: prog.x
Reading symbols from /home/user/prog.x...
WARNING: unable to determine length of string variable.
(repeats another couple of times )
So what does this warning mean ??? and which variable is it referring to ? possibly this could be the source of my bug. But I need something more in order to locate this.
help ?
J
Please report this to Intel Premier Support - this sounds as if it could be a bug in either the compiler or idb.
