29533 Discussions
Debugging Cray pointer in VS2005 or VS2003
pierre_archambeau1
When I try to debug a cray pointer (using pointer(p,x)) in Visual Studio 2005 or 2003, I get amessage "not defined address". I can'tget the value or the array associated with the pointer.Does someonehave a solution to debug the cray pointer in these environment? In the 2000 version (Compaq Fortran 6.6) the debugger works perfectly.
Please send an example to Intel Premier Support so that this can be investgated.
