29651 Discussions
Can't display source code in debugger following Fortran Include
michael_franke
Hi.
I have a Fortran project which contains a number of sizeable blocks of code that are included using the Fortran Include statement. It seems that as soon as I hit the first such block of code, I can no longer display source code in the debugger.
Is there a way around this (other than eliminating the Includes?).
Mike
Please submit a sample project showing this problem to Intel Premier Support. That's not normal behavior.
TimP
Do you get warnings from Microsoft link about .pdb corruption? If so, that would be the point which you should reproduce in a problem report on premier.intel.com.
Lorri_M_Intel
Hi -
What version are you using? We've had some problems in earlier versions with this sort of issue, especially when the 'includes' were done using C-style includes, and the Fortran preprocessor.
thanks -
- Lorri
