29251 Discussions
out of memory when reading a record from unformatted file
felotti
I get the following message
forrtl: severe (98): cannot allocate memory for the file buffer - out of memory, unit 22, file D:BIGmensola.VIR
when I try to read a record from an unformatted file.
In a subroutine I write a 'big' record of integer*4
write(vir) ia(1:n)
where N=97.954.383
Next in the program, I try to read the record and I get the error in the subject.
The length of the 'record' is 97954383*4*8 = 3.134.540.256 bit > HUGE(1) = 2**31.
Why I can write the roecord and I cannot read it?
There is some limit to the 'lenght' in bit of a record?
Is array IA dimensioned 1:N? If so, try removing the (1:n) from the WRITE and READ.
jimdempseyatthecove
Steve.
??> The length of the 'record' is 97954383*4*8 = 3.134.540.256 bit > HUGE(1) = 2**31.
Would this imply that file I/O is bit granular? Or at least record size is bit granular?
Jim Dempsey
No, it is not bit granular. But large unformatted records are split into segments as documented in the Building Applications manual.
felotti
The real code, for writing the file is the following:
c
c we store on VIR file for future usage
c
nfvir=iunit ('VIR',nerror)
rewind (nfvir)
c
c 1.st record on VIR : master record
c
write(nfvir)neq,ntote
c
c 2.nd record on VIR : columns (1,...,NTOTE)
c (currently unuseful)
c
c write(nfvir)(iarea (k,1),k=1,ntote)
call writearr( nfvir, iarea, ntote)
c
where the subroutine WRITEARR is the following:
subroutine writearr( iunit, ia, n )
dimension ia(n)
write(iunit) ia
return
end
Really, I must skip the record, and my original source code is:
c
c get info on the nfvir file
c
rewind (nfvir)
read (nfvir)i,j ! neq, nonz
read (nfvir)! (iarea (k,1),k=1,ntote)
c read (nfvir)(ipoint(l),l=1,neq+1)
read (nfvir) ipoint
I get the error on the 2nd READ, when I try to skyp the 'big' record.
I tried to do it with the following code:
read (nfvir)idum! (iarea (k,1),k=1,ntote)
but I get always the error message.
That sounds like a bug. Please report it and provide a sample program.
felotti
I compiled my program as 64 bit application and the code works without problem: the 'big' record is skipped.
That somewhat makes sense - I don't know how you would be able to process a large record if you did not have sufficient address space.
