Hi all,
I have a baffling issue in a large application I have been working on. I have a previous version of this application that worked fine at all levels of optimization, but some recent changes I made seem to have broken the program. The program crashes out with a segmentation fault if I try to compile it -O1 or above, but does notcrash at -O0 (which is automatically turned on with -g). What's worse is that print statements inserted into the code seem to affect whether the code crashes or not...I can successfully run at -O3 if I load the program up with diagnostic print statements. My hunch is that this is some sort of out-of-bounds error which is not being caught, and that it doesn't manifest when the for loops are not unrolled (hence it works at -O0).
I have tried -check all, -ftrapuv, -nozero, -warn all at -O0 through -O3, but nothing is being caught when the program crashes. Are there any other compiler flags for ifort that could help me troubleshoot this issue?
Thanks for reading.
First of all, forget -ftrapuv. It does nothing useful. Which compiler version are you using?
ifort (IFORT) 11.1 20091130
I have actually just tried compiling the same program in gfortran, and it has the same behavior...crashes at anything above -O0.
Some additional details: I am using openmpi, so ifort is being run through the mpif90 wrapper. Also, the crash is occuring within a functor. The segmentation fault error at -O1+ looks like the following:
*** Process received signal ***
Signal: Segmentation fault (11)
Signal code: Address not mapped (1)
Failing at address: 0x18
[ 0] /lib64/libpthread.so.0 [0x3979c0e4c0]
[ 1] application_name(eos_helm_+0xe) [0x542a0e]
[ 2] application_name(eos_newt_functions_mp_newt_eos_+0xfb) [0x5461ab]
[ 3] application_name(fminln_mp_fmin_+0x10a) [0x54a8ca]
[ 4] application_name(annewt_+0x13a) [0x51cafa]
[ 5] application_name(newt_wrappers_mp_run_annewt_+0xd6) [0x6c0036]
[ 6] application_name(eos_+0x7ee) [0x445f5e]
[ 7] application_name(wd_intout_+0x2228) [0x6d7828]
[ 8] application_name(simulation_init_+0x50e) [0x48369e]
[ 9] application_name(driver_initflash_+0x5c5) [0x444205]
[10] application_name(MAIN__+0x3b) [0x44d71b]
[11] application_name(main+0x3c) [0x43ee4c]
[12] /lib64/libc.so.6(__libc_start_main+0xf4) [0x397941d974]
[13] application_name [0x43ed59]
Well, that it also fails with gfortran tells you something. I believe you can use -G -O1 to get debug symbols but some optimization. Looks as if it's failing in a pthread call, suggesting to me that you've corrupted the stack or some other data area.
One thing you can do is selectively compile sources with -O1 and see which one (hopefully) is required to be -O1 to get the error.
You could throw all the diagnostic options at it as well:
-g -O1 -traceback -check all -gen-interfaces -warn interfaces -fp-stack-check
and run the code.
ron
and run the code.
ron
