29649 Discussions
Debugging negative pressure values using traceback in Intel oneAPI on Windows
Niyas
Hello everyone,
How can I use the traceback function in my 3D numerical simulations in Fortran, while using a Windows computer and Intel oneAPI, to identify the cause of negative pressure values and what is the command for it?
mecej4
At the various locations in your code where new values of pressure are calculated, you can add a couple of diagnostic statements along the lines of
pnew = ....
if (pnew < 0.0) then
   print *, i,j,k, t, vx, vy, vz, ..., ' p new is negative'
   call tracebackqq(...)
endif
p(i,j,k, m) = pnew
Niyas
@mecej4  Thanks for your reply.
I am just getting started with traceback and debugging.
Can you please give me an idea about the 'tracebackqq' subroutine? What should it do ?
mecej4
Tracebackqq() is provided by the compiler, and is documented in the compiler development reference guide  .
