Debugging oddity
anthonyrichards
New Contributor III
I'm using IVF 11.1.035 . The debug configuration has optimization disabled.
While debugging the following code, I found the following 'odd' behaviour with the highlighting:
With the breakpoint set at the line indicated, the program ran and stopped at the break point, which is first highlighted in yellow in the debugger (subsequently in red when stepped past it). Thefirst stepover caused the program to step to the next executable line, the first SendMessage function call. However, the next stepover caused the yellow highlight to jump to the THIRD Sendmessage (skipping executable lines), the next stepover returned the highlight to the FIRST SendMessage, the next stepoverset the highlight to the second Sendmessage, the next stepover set the highlight to the THIRD Sendmessage, jumping two executable lines of code, the next stepover sent the highlight back to the SECOND SendMessage, after which subsequent stepovers progressed normally line by line.
! define a font for the APPLY and EXIT buttons
LF = T_Logfont(-20,0,0,0,1000,1_1,0_1,0_1,0_1, &
0_1,0_1,0_1,0_1,"Arial"C)
[Breakpoint-->] hfont=CreateFontIndirect(LF)
!Set the font for the Apply button
lret=SendMessage( GetDlgItem(dlg%hWnd,IDM_APPLY),WM_SETFONT,hfont,MAKELPARAM(TRUE, 0))
!Set the font for the Exit button
lret=SendMessage( GetDlgItem(dlg%hWnd,IDM_EXIT),WM_SETFONT,hfont,MAKELPARAM(TRUE, 0))
! define a TAB font
LFTAB = T_Logfont(-15,0,0,0,1000,1_1,0_1,0_1,0_1, &
hfonttab=CreateFontIndirect(LFTAB)
!Set the font for the tab control
lret=SendMessage( GetDlgItem(dlg%hWnd,IDC_TAB),WM_SETFONT,hfonttab,MAKELPARAM(TRUE, 0))
What's happening?
Lorri_M_Intel
Because you compiled with optimizations disabled,this sort ofwild jumping around behavioris (usually)because we've missed someof linenumber information that's passed to the debugger.
Would you mind attaching a compilable piece of code, builtaround your snippet? Doesn't have to be executable, certainly doesn't need to do anything productive, but just have enough USE statements (or whatever) so that I can compile it with some of our magic tools to check the internal line number representations?
You're using 11.1 Update 1, correct? I don't see where we've had to do anything with the linenumber information in the 11.1 timeframe at all, so the usual advice of checking a current compiler may not help you. Of course, if you have access to a later compiler, it wouldn't hurt to try it.
thanks --
- Lorri
anthonyrichards
New Contributor III
Sure. I use IVF 11.1.035. Here are all the files that make up the project.
Lorri_M_Intel
Thank you, yes I can reproduce the bad line numbers. It's the WM_SETFONT that is being passed by value to the three different SendMessage calls. For some reason, we're assigning the same line number to all three instances. (In case it's not obvious, the line number is for the last instance.)
I'll create an internal problem report; how painful is this to you?
- Lorri
anthonyrichards
New Contributor III
Thanks. It's no big deal for me, so take your time!
Lorri_M_Intel
OK, the internal id is DPD200150374. I'm sure you'll hear when something interesting happens with it.
- Lorri
This has been fixed in our sources - the fix will appear in a future update.
