29422 Discussions
Declaration of routine 'DROUND' conflicts with a previous declaration
davidgraham
When I compiled I got "Declaration of routine 'ROUND' conflicts with a previous declaration". I had never got this error before when I compiled and had not changed the function.
I therefore renamed the function to 'dround' but get the above error. I've even deleted all the files in the debug directory and recompiled - I don't know what I'm doing wrong.
integer*4 function dround (d)
! round double precision value to integer*4
real*8 d
if (d.ge.0d0) then
d=d+5d-1
else
d=d-5d-1
endif
dround=d
return
end
interface
real*8 d
end function
end interface
Arjen_Markus
Can you show us the exact source you are compiling? The fragment you show is not
valid Fortran and the cause of the error message is likely located in the code you
have not shown.
BTW, your rounding function is changing its argument, d. That may not be quite
what you want.
Arjen
davidgraham
Arjen,
It's a large project, here are the two bits of code that I think are important.
round.ffn is the function - I add that to may large project using an include statement in a file include.f90
! other includes
include 'rotlim.fsb'
include 'round.ffn'
include 'reqHts.ffn'
! etc
round.fif is the interface which is also added as using an include statement at the start of any routine that uses the function.
include 'round.fif'
Arjen_Markus
You do not include the round.ffn file twice, by any chance?
Arjen
davidgraham
No, I've checked.
I edited a file I have never edited before, compiled and got this error. I wondered if that file contained its own function 'round' but it doesn't. Decided to change the name of my function to 'dround' but it still won't compile.
Is all this code in a module or are contained procedures? It is an error to declare an explicit interface in a scope where the function itself is defined. Your use of include files makes me think you are doing this.
davidgraham
I think I have solved it.
I think the error I listed was the second error in the error list.
Once I fixed the first error, the second disapeared.
David
