29650 Discussions
DefWindowProc Attributes Declaration
garyscott
In order to resolve a linking error for defwindowproc, I have to change the attributes declaration from:
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'DefWindowProcA' :: DefWindowProc
to:
!DEC$ ATTRIBUTES DEFAULT, STDCALL, ALIAS:'_DefWindowProcA@16' :: DefWindowProc
version.lib kernal32.lib and user32.lib are specified on the link command
What is the difference in the above?
Shouldn't be any difference if the interface defines four arguments, which it seems to. What symbol is the linker looking for if you don't make the change? What compile options are specified?
Jugoslav_Dujic
Valued Contributor II
There's supposed to be no difference (except that DEFAULT is supported since CVF 6.5), however...
I filled in a bug report (found outin a subclassing example, "Menu Dialog") where CVF cannot work out a reference on calling side if you don't ever actually directly call the routine, but reference it by other means, for example:
subroutine Foo
use dfwin
iMsg = CallWindowProc(LOC(DefWindowProc), hWnd, Msg, wParam, lParam)
end subroutine Foo
Steve explained to me that it's difficult to get right (I agree) and that it won't get fixed. A workaround is to... find a workaround. For example, adding a
if (.false.) then
iMsg = DefWindowProc(hWnd, Msg, wParam, lParam)
end if
"explains" to the compiler what DefWindowProc really is, automagically fixing the first error (if the optimizer doesn't remove unreachable code :smileywink:).
Is that your situation? Note that you may call DefWindowProc directly, not via CallWindowProc (semantic differences are subtle and you can usually ignore them).
Jugoslav
garyscott
Link is looking for "_defWindowProcA"
i.e. no decoration assumed by link. Argument passing convention options are:
DEFAULT, UPPER CASE, STRING LENGTH ARGUMENT INLINE
It is true that I'm not making a direct call to this routine anywhere. I'm simply assigning it to thelpfnWndProc component of the window class structure destined for registerclass: = loc(defwindowproc) !MsgLoop
Linking works also if I map an undefined alias name for it (i.e. myMSGLoop, without defining such a function in my code).
link options:
c:gino60gmenuwdg.lib c:gino60ginlibdg.lib c:gino60gmwinerr.lib version.lib kernel32.lib user32.lib u:f95sourceezconsole eleaseezconsole.lib /nologo /entry:"mainCRTStartup" /subsystem:windows /incremental:no /pdb:"Release/TestGino50.pdb" /machine:I386 /out:"Release/TestGino50.exe"
Note: entryused by GINO app.
EXE compile options:
/compile_only /debug:none /include:"Release/ u:f95sourceezconsole elease" /nologo /warn:nofileopt /winapp /module:"Release/" /object:"Release/"
Static library compile options:
/compile_only /nologo /warn:nofileopt /module:"Release/" /object:"Release/"
garyscott
I am not calling it directly, I am assigning it to a structure componentfor use in the registerclass API (see my other post). Is thatthe same situation you describe?
Ah, yes, now I remember. The DECORATE attribute doesn't work if you're not actually calling the routine. I think that for this routine, at least, it might make sense for us to not use DECORATE and spell out the name in full.
Jugoslav_Dujic
...while you're at it, DefDlgProcand DefMDIChildProc fall in the same category.
Jugoslav
Jugoslav_Dujic
...to Garry: you can workaround it if you manage to call DefWindowProc from the same procedure (WinMain?). I think that inserting:
iRet = DefWindowProc(GetDesktopWindow(), WM_NULL, 0, 0)
anywhere (even as a last line)causes no harm, and resolves the problem.
Jugoslav
garyscott
Thanks. I have resoved it by creating a "properly structured" message loop of my own with explicit fall-through call to defwindowproc within. My prior setup was intended to be temporary while I tested other code (tweaking the window settings themselves before moving on to the message loop).
