Default output extension not .dll?
dajum
I'm compiling a source to be a dll, but by default it makes it an .exe.  What am I doing wrong?  I thought /dll would make the extension .dll.
Here is my command line in windows.
ifort f6070.for @props.txt
where props.txt contains:
  /debug:full /Qopenmp /fpe:0 /real_size:64 /integer_size:64 /names:lowercase  /iface:cref /I:"..\..\x64\Current" /MD /iface:mixed_str_len_arg  /libs:dll /threads /include:"..\..\x64" /assume:byterecl /extend_source:132 /Od /traceback  /INCREMENTAL:NO /link /LIBPATH:"..\..\Dlls_x64" "..\..\x64\ProcessModulesDll_16.lib" "..\..\astap\x64\debug\astap_16.lib" "..\..\x64\procesCur16.lib" "..\..\x64\utilityCur_16.lib" /MAP /MANIFEST /dll
Dave
You have /dll after /link but need to put it before that.
dajum
Thanks Steve!
dajum
Another issue with this.  When I was specifying the output file name, I could load the symbols into the debugger and step into the code.  Now it says the .pdb image doesn't match.  Any help with that?
I don't see where you've specified the PDB file. My advice is to build this in Visual Studio and then copy the options from the build there.
