Denormal number
Zuheyr_A_
I am using intel compiler 9.1.045/bin/ifort on Linux and compiling with flags
-g -O0 -mp -debug all -save -check all -traceback -integer-size 64 -real-size 64
My program does not give me the answers I got with other compilers and I keep on getting the following warning (but program continues):
Fortran runtime warning: IEEE 'denormal number' exception not supported.
Could you please point out what is wrong with the code!? Is it because there are denormal numbers or is it warning that denormal number check is not supported!?
I would greatly appreciate your help.
Thanks for reading,
Zuheyr Alsalihi
Ron_Green
Zuheyr,
You can check for FP exceptions by using:
-fpe:0 -no-ftz
Now if you want numerics to be precise, your version of the compiler, remove "-mp" and use "-fp-model precise". Check the documentation of -fp-model, for your older 9.1 compiler it may be in the Release_Notes document as this was a new option about the time your compiler was created. It is documented fully in the 10.1 compiler family.
ron
