29343 Discussions
Derived type pointer components and intent(in) are out?
Moved from separate thread as it's a new issue.
IanH
Not quite there yet.
[fortran]MODULE TheUpdateGivethAndTheUpdateTakethAway
  IMPLICIT NONE
  TYPE :: Parent
    INTEGER :: a
  END TYPE Parent
  TYPE, EXTENDS(PARENT) :: Extension
    INTEGER :: b
  END TYPE Extension
  TYPE HasDefinedAssignment
    INTEGER :: c
  END TYPE HasDefinedAssignment
  TYPE Container
    TYPE(Parent), POINTER :: ptr_comp
    CLASS(Parent), POINTER :: poly_ptr_comp
    TYPE(HasDefinedAssignment), POINTER :: da_ptr_comp
  END TYPE Container
  INTERFACE ASSIGNMENT(=)
    MODULE PROCEDURE defined_assignment
  END INTERFACE ASSIGNMENT(=)
CONTAINS
  SUBROUTINE ThisAlwaysWorked(arg)
    TYPE(Container), INTENT(IN) :: arg
    arg%ptr_comp%a = 1
  END SUBROUTINE ThisAlwaysWorked
  SUBROUTINE ThisIsStillBroken(arg)
    arg%da_ptr_comp = 2
  END SUBROUTINE ThisIsStillBroken
  SUBROUTINE ThisNowWorkswith_12_0_3(arg)
    CALL modify_a_parent(arg%ptr_comp)
  END SUBROUTINE ThisNowWorkswith_12_0_3
  SUBROUTINE ThePreviousWorkAroundIsStillOk(arg)
    p => arg%ptr_comp
    CALL modify_a_parent(p)
  END SUBROUTINE ThePreviousWorkAroundIsStillOk
  SUBROUTINE But_12_0_3_BrokeThis(arg)
    SELECT TYPE (s => arg%poly_ptr_comp)
    TYPE IS (Extension)
      s%b = 1
    END SELECT
  END SUBROUTINE But_12_0_3_BrokeThis
  SUBROUTINE TheWorkAroundIsStillOk(arg)
    p => arg%poly_ptr_comp
    SELECT TYPE (p)
    TYPE IS (Extension)
      p%b = 1
    END SELECT
  END SUBROUTINE TheWorkAroundIsStillOk
  SUBROUTINE defined_assignment(lhs, rhs)
    TYPE(HasDefinedAssignment), INTENT(OUT) :: lhs
    INTEGER, INTENT(IN) :: rhs
    lhs%c = rhs
  END SUBROUTINE defined_assignment
  SUBROUTINE modify_a_parent(parent_arg)
    TYPE(Parent), INTENT(OUT) :: parent_arg
    parent_arg%a = 1
  END SUBROUTINE modify_a_parent
END MODULE TheUpdateGivethAndTheUpdateTakethAway
[/fortran]
[plain]>ifort /c /warn:all /check:all PointerIntentTest.f90
Intel Visual Fortran Compiler XE for applications running on IA-32, Version 12.0.3.175 Build 20110309
Copyright (C) 1985-2011 Intel Corporation.  All rights reserved.
PointerIntentTest.f90(35): error #6780: A dummy argument with the INTENT(IN) attribute shall not be defined nor become undefined.   [ARG]
    arg%da_ptr_comp = 2
PointerIntentTest.f90(57): error #6780: A dummy argument with the INTENT(IN) attribute shall not be defined nor become undefined.
      s%b = 1
compilation aborted for PointerIntentTest.f90 (code 1)[/plain]
Thanks - we'll take a look at this.
