29425 Discussions
Detemine what subroutines were uses in an executable
carlls
Greetings:
I find myself needing to know what subroutine ( only names not versions ) are used in a given exe.
Now I already to know how to do this with library and object files, I use dumpbin /symbols name.obj and do OK.
I also know that if I use SCCS ids or CVS IDENT strings I could use the what or ident command... but that means updating the source.
De-buggers have to be able to do this, so the data is there ..... any idea on how to get at the data?
Carl
The data is not there, unless you have linked a debug executable and then the symbols will be in a separate PDB file. If you ask the linker to create a link map, you can find names in it, but there isn't a way to take some random EXE and extract routine names from it.
jimdempseyatthecove
Have you tried DLLEXPORT?
I believe you can DLLEXPORT procedure names without linking to a DLL or being a DLL. The names and offsetsshould be visible in the .exe file. Someone probably has a free utility that lists the exported names.
Jim Dempsey
That does work - but still requires changing the code or writing a .DEF file to define the exports. You can dump them with "dumpbin -exports" from a Fortran command prompt.
