Difference between form='unformatted' and form='binary'?
Kai_G_
Does anyone know what is the exact difference between the form='unformatted' and form='binary' in open() when writing/reading raw binary files? Seems that form='binary' is not available in fortran compilers such as gfortran. I read the documentation for FORM in https://software.intel.com/en-us/node/525755#E6F9FE02-2CA6-468D-B8D5-E2AA56FF2CC1, but still do not quite understand the difference. For stream access read/write, is there any difference between using form='unformatted' and form='binary'?
Thanks!
mecej4
Unformatted files contain record-length information, encoded in a vendor-specific way, interspersed with the data, in the file.
Files with FORM='BINARY' are nonstandard, and contain no record-length information. Such files may have been written by a C program after having been opened with fopen(<file_name>,"wb") (or otherwise), and being able to use FORM='BINARY' allowed stream access in the decades before stream access was added to the Fortran standard.
One has to look at the history of I/O devices from the 1950-s to today in order to see why the file OPEN statement has such a large variety of optional clauses. The old tape and DASD files were not at all in harmony with the "stream of bytes" view that Unix adopted.
Steven_L_Intel1
FORM='BINARY' should not be used anymore - instead use the standard ACCESS='STREAM' (with FORM='UNFORMATTED').
[Edited to correct keyword from RECORDTYPE to ACCESS]
Kai_G_
Steve Lionel (Intel) wrote:
FORM='BINARY' should not be used anymore - instead use the standard RECORDTYPE='STREAM' (with FORM='UNFORMATTED').
Thanks, Steve. May I know why the FORM='binary' is not recommend to be used anymore in modern Fortran? If I want to read/write stream file, can I use ACCESS='STREAM' + FORM='UNFORMATTED' without RECORDTYPE?
Also, for direct access, if a file was written with ACCESS='DIRECT' + FORM='BINARY', could it be read seamlessly with (recommended) ACCESS='DIRECT' + FORM='UNFORMATTED'?
Thanks a lot!
Kai_G_
Thanks for the reply. Seems complicated and I need to do a research on this...
TimP
form='binary' was a vendor-dependent extension for which 'stream' files were adopted as a standard replacement.  You might consider replacing files written that way by reading (with the same vendor's compiler) with the 'binary' options and writing out with current standard options.
Steven_L_Intel1
As Tim says, FORM='BINARY' was an extension - Microsoft's, I think - that got picked up by others. There is no reason to use it now that the standard has ACCESS='STREAM' (this is what I meant instead of RECORDTYPE='STREAM'). Both are just "a stream of bytes". There is no need to read with one and write with the other.
Taves__Mike
Theses two OPEN statements are equivalent when writing a file:
  • Non-standard: open(unit=20,file=fname,form='binary')
  • Standard: open(unit=20,file=fname,form='unformatted',access='stream',status='replace')
​Note that without status='replace', it defaults to 'UNKNOWN', which is "processor dependant" (according to the Fortran 90 Standard). I have found with ifort and gfortran on Linux that if a file already exists, it is not deleted first, and the bytes just replace over the old file. And if a smaller number of bytes are written, the remaining parts of the file remain (i.e. the file is a mess). Therefore I recommend adding "status='replace'" to make a compatible switch from non-standard "form='binary'" to unformatted stream access files.
