29525 Discussions
Fatal called in wrf 3.8.1 with intel compilers
Fernando_M_3
I'm trying to compile and run wrf model 3.8.1 with compiler intel parallel studio xe 2016 update3, in rhel Enterprise Server 7.2. The processors are Intel(R) Xeon(R) CPU E5-2690 v3 @ 2.60GHz.
Following this url:
https://software.intel.com/en-us/articles/how-to-get-wrf-running-on-the-intelr-xeon-phitm-coprocessor
All compilation modules ends ok, but when run wrf.exe, it stops with this message:
rank 9 in job 11  master_33806   caused collective abort of all ranks
  exit status of rank 9: killed by signal 9
rank 4 in job 11  master_33806   caused collective abort of all ranks
  exit status of rank 4: killed by signal 9
rank 3 in job 11  master_33806   caused collective abort of all ranks
  exit status of rank 3: killed by signal 9
rank 2 in job 11  master_33806   caused collective abort of all ranks
  exit status of rank 2: killed by signal 9
And the file rsl.error.0000 is:
taskid: 0 hostname: master
 module_io_quilt_old.F        2931 F
 MPASPECT: UNABLE TO GENERATE PROCESSOR MESH.  STOPPING.
  PROCMIN_M            1
  PROCMIN_N            1
  P                   -7
  MINM                 1
  MINN                -7
-------------- FATAL CALLED ---------------
FATAL CALLED FROM FILE:  module_dm.b  LINE:     155
module_dm: mpaspect
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
Previously, I test configre wrf with option 20 (dmpar) INTEL (ifort/icc): Xeon (SNB with AVX mods), with same results... (same error in wrf.exe)
Thanks in advance
