29641 Discussions
deallocate type variable only one field
diedro
Dear all,
I have the following type variable:
  TYPE::tMACROCELLNODE
   INTEGER                                        :: nElem
   INTEGER                                        :: AA
   INTEGER                                        :: IDnode
   INTEGER                                        :: IDmCell
   REAL(KIND=8),ALLOCATABLE,DIMENSION(:)          :: WFX
   REAL(KIND=8),ALLOCATABLE,DIMENSION(:)          :: WFY
   REAL(KIND=8),ALLOCATABLE,DIMENSION(:)          :: WFtime
   REAL(KIND=8),ALLOCATABLE,DIMENSION(:)          :: WFpdf
   REAL                                           :: qs
  ENDTYPE
During my program, I allocate it as:
first of all:
ALLOCATE(MACROCELLNODE(npairs))
and then
DO i.....
       ALLOCATE(MACROCELLNODE(i)%WFX(n))
My question is:
Is it possible deallocate only one field of it?
for example:
i=10
DEALLOCATE(MACRCELLNODE(i)%WFX(:))
Thank to all of you
Diego
Yes, you can do that. You can also deallocate the entire array and each of the components will be deallocated as necessary.
You have the syntax a bit wrong in the DEALLOCATE, though - no (:) at the end.
diedro
Dear all, Dear Steve,
Thanks a lot, but what is the difference between
VECTOR(:) or VECTOR?
Just to better understand
Thanks again
mecej4
When you allocate an array, you have to specify the extent of the array. When you deallocate, however, you do not specify a range of indices. You may deallocate only the entire array, and not chosen portions of it. Therefore, writing (:) in the deallocation statement would be superfluous, and the language rules do not let you write that qualifier.
