29657 Discussions
Different behavior Passing Real/Complex Arguments
dannycat
I am currently trying to convert a legacy FORTRAN IV program from essentially single precision to double by making as few modifications as possible. The program uses subroutine arguments to allow psuedo dynamic array sizes where some of these arrays are complex data types.
The original programpasses anreal*4 array into the subroutineand an effectively maps this onto a Complex*4 array withinand upon examining the data in the debugger this seems to work. However when both arrays are changed to Real*8 and Complex*8 this no longer seems to be the case. I have reproduced the problem in the program below.
program testcomp
implicit none
real*4 Q(2,10)
real*8 Q8(2,10)
integer j
call Sub4(Q)
write(*,'(A)') ' Real*4 Results'
do j = 1 , 10
write(*,'(2ES15.5)') Q(1,j),Q(2,j)
enddo
call Sub8(Q8)
write(*,'(/A)') ' Real*8 Results'
do j = 1 , 10
write(*,'(2ES15.5)') Q8(1,j),Q8(2,j)
enddo
read(*,*)
end
subroutine Sub4(T)
implicit none
complex T(10)
real r,im
integer i
do i = 1 , 10
r = float(i)
im = r/2.0
T(i) = cmplx(r,im)
enddo
return
end subroutine
subroutine Sub8(T)
implicit none
complex*8 T(10)
real*8 r,im
integer i
do i = 1 , 10
r = dble(float(i))
im = r/2.0d0
T(i) = dcmplx(r,im)
enddo
return
end subroutine
Real*4 Results
1.00000E+00 5.00000E-01
2.00000E+00 1.00000E+00
3.00000E+00 1.50000E+00
4.00000E+00 2.00000E+00
5.00000E+00 2.50000E+00
6.00000E+00 3.00000E+00
7.00000E+00 3.50000E+00
8.00000E+00 4.00000E+00
9.00000E+00 4.50000E+00
1.00000E+01 5.00000E+00
Real*8 Results
3.05176E-05 7.81250E-03
1.25000E-01 2.00000E+00
8.00000E+00 3.20000E+01
1.28000E+02 5.12000E+02
1.02400E+03 2.04800E+03
0.00000E+00 0.00000E+00
If you examine the contents of Q and Q8 they differ. ie Q looks OK but Q8 doesn't. I know this is not an ideal way of programming but I don't want to have to rewrite the whole program if it can be avoided. Is this as expected behavior and if it is does anyone know the best way to get this working correctly without resorting to a major rewrite?
This was compiled using CVF 6.6c (with Argument Mismatch check disabled)
complex*8 is not the same as complex(8) complex*8 is single precision complex. You want complex*16 or complex(8).
dannycat
Steve,
Ah, I see, its obvious now. The 8 refers to both real & imaginary parts together. I've not used these data type before.
Put another way, the *n refers to the length of a value in bytes. A complex*8 is two real*4s.
