29640 Discussions
Different behaviour for allocatable and automatic arrays
wayne_lewis
I am noticing different behaviour when I create a large array in two different ways.
If I use the allocatable method:
[cpp]subroutine array_function(array_size)
  implicit none
  integer :: array_size
  integer, allocatable :: array(:)
allocate(array(array_size))
end subroutine
[/cpp]
and call this with
[cpp]array_function(300000)[/cpp]
everything works fine.
If I define the function as:
  implicit none
  integer :: array(array_size)
end subroutine[/cpp]
and call it with
I get the following error at run time:
forrtl: severe (170): Program Exception - stack overflow
Image PC Routine Line Source
array_test.exe 00447897 Unknown Unknown Unknown
array_test.exe 0040116E Unknown Unknown Unknown
array_test.exe 004637C3 Unknown Unknown Unknown
array_test.exe 004527CE Unknown Unknown Unknown
kernel32.dll 7C816FD7 Unknown Unknown Unknown
I am using Intel Visual Fortran Compiler IA-32, Version 11.0, Build 20090318.
I am launching the compiler from a Cygwin terminal session, using the following command:
/usr/local/bin/ifort -c /QaxSSE4.1 /MT /fpp /Qvec-report0 /check:bounds /warn:all array_test.f90 -o
array_test.obj
Note that the file contains the function described above and a small test program to call the function.
thomas_boehme
New Contributor II
Quoting - wayne.lewis
  implicit none
end subroutine
[/cpp]
and call this with
  implicit none
and call it with
array_test.obj
By default, automatic arrays are allocated on the stack, whereas the one you explicitly allocate are not. The stack size is not large enough to hold your 300000 element array.
You could either increase your stack size (don't remember the setting right now), or you could tell the compiler to allocate large temporary arrays on the heap rather than on the stack. For that, set the option Fortran->Optimization->Heap Arrays.
Thomas
reinhold-bader
New Contributor II
in contrast to allocatable variables, which are allocated on the heap, automatic variables are taken from the stack. Apparently your default stack size is insufficient; to get around this problem, you can either use the /F option - in your case /F1200000 for 300000 * (size of integer) bytes - or specify /heap-arrays, which would enforce using the heap for automatic arrays as well.
Reinhold
TimP
Quoting - reinhold-bader
These are among the arguments in favor of ALLOCATABLE rather than automatic array, taking advantage of the STAT and ERRMSG options to check for and inform about the location of any failure.
