29653 Discussions
Different results when using a shared library in an executable and in python
raf3
I encountered a strange behavior when using the compiler options -fPIC and -fp-model=strict with ifx (IFX 2025.1.0 20250317).
I’ve attached a minimal reproducible example to this message.
I use the followings bash script to compile and launch two different cases:
#!/bin/bash
opt1='-O2 -fPIC '
opt2='-O2 -fPIC -fp-model=consistent'
opt3='-O3 -fPIC -fp-model=strict'
opt=$opt3
echo "Result in direct launch (dynamic)"
rm -rf test *.o *.so
ifx -shared $opt my_function.f90 -o my_function.so
ifx $opt test_main.f90 my_function.so -o test
export LD_LIBRARY_PATH=".":$LD_LIBRARY_PATH
./test
echo "Result in python"
python3 launch.py
In the first case, a shared library is created and used by an executable.
In the second case, the same shared library is used in Python.
The results differ between the two cases, I get the following results:
dval real = 5823048.334457053, hexa = 415636921567BE8E
calc real = 233.2397881329337, hexa = 406D27AC58299D6A
Result in python
calc real = 233.2397881329337, hexa = 406D27AC58299D6B
Can you reproduce this behavior? Is it expected, or is it a bug?
If relevant, please note that I’m using ifx on a Red Hat 8 Linux system.
Raphaël
