Hi Everybody,
I need to compile a hydrological model (SWAT) thas was wrote in Fortran. I downloaded the source code from the site of the model and compiled it using Intel Fortran Compile on Visual Studio 2017.
First I compiled this source code as a library and made some tests that generated the output files as expected.
After this, I compiled this same source code as an executable and made again the same tests to generate the output files.
When I compare these output files the result of the calculations from the model is quite different but the source code and the input information are totally equal.
The executable version made a correct output file but I would like to get a library version for my work.
This model puts a lot of information (variables, arrays) and calculations on the computer`s memory that I think that is a problem of memory management from the library version that made the results wrong.
Somebody could help me with some tip to resolve this problem,
Thank's
