Disappearing graphics window
WSinc
Hello -
When I set a breakpoint and it goes there, it appears that the only way to see a graphics window is to put the mouse on the taskbar. But I have to LEAVE it there or the window disappears.
So that means I can't do anything with the window, i.e.can't copy resize, or scroll it, etc.
This is for debugging purposes mostly.
Is there a way around this? I have to resort to putting a read statement where I want execution to stop,
then the window stays put. But then that defeats the point of having a breakpoint there.
I am using Windows 7.
Paul_Curtis
Valued Contributor I
[bash]SUBROUTINE Set_Topmost (hwnd)
    IMPLICIT NONE
    INTEGER(HANDLE), INTENT(IN)     :: hwnd
    INTEGER                         :: rval
    rval = SetWindowPos (hwnd,HWND_TOPMOST,0,0,0,0,IOR(SWP_NOSIZE,SWP_NOMOVE))
END SUBROUTINE Set_Topmost
[/bash]
The problem is that when you hit a breakpoint, all threads in your program stop, including the one responding to Windows messages to repaint, etc. It's a general problem debugging windowing applications and one without a really good solution. What I sometimes do is move the graphics window to be beside the Visual Studio window, so that when the program pauses, I can see what was in the window and not have it obscured by the debugger.
WSinc
But then you still can't actually do anything with it, right?
I would like to be able to scroll the contents down to catch info that
appeared before. Or print out the contents, etc.
Is there a way to fake it out with a background process that keeps the window alive?
Yours; Bill S.
Correct - you can't do anything with it and as soon as you overlap it with another window, you lose what was there. If you're using a console window, no problem, but QuickWin or a windowing app (where your program manages the windows) will have this problem.
I don't know how you could "fake it out" unless you structured your application into separate processes, which is a major undertaking.
