Discrete subscripts
h_amini
Hello there
Can the subscripts of an array be discontinuous?
For example, how can I define a rank-one array (I) containing the elements I(5), I(6), I(21) and I(22).
Hamid
You can't define an array like that, but you can reference those elements with a vector subscript, for example:
I([5,6,21,22])
h_amini
I([5,6,21,22])
Thank you for this. Do you mean using something like the following program?
INTEGER I(4)
I = (/5,6,21,22/)
I(5)=50; I(6)=60; I(21)=210; I(22)=220
PRINT*, I(5), I(6), I(21), I(22)
END
h_amini
Quoting - h.amini
I([5,6,21,22])
INTEGER I(4)
I = (/5,6,21,22/)
END
Something should be wrong. He program works with more subscripts, e.g. I(7), I(8), I(23) and I(24).
INTEGER I(4)
I = (/5,6,21,22/)
I(7)=70; I(8)=80; I(23)=230; I(24)=240
PRINT*, I(7), I(8), I(23), I(24)
END
No, that's not what I meant. The program you have here is invalid as array I is dimensioned (4) and you are referencing far outside its bounds.
What I meant was something more like this:
[plain]INTEGER I(25)
PRINT*, I([5,6,21,22])
PRINT*, I([7,8,23,24])
END[/plain]
h_amini
END[/plain]
Many thanks. But you defined a 25-element array. I wanted to have elements as less as possible, which would be an 8-element array for the above example (or 4-element for the first example).
As I indicated earlier, you can't do that in Fortran. I suppose what you could do is define a second array with indexes into the first, but this would not save you any storage.
h_amini
So the best solution seems to be defining an array with elements from the minimum to the maximum values. As I need dynamic variables, the program in post 4 will be:
INTEGER, ALLOCATABLE :: I(:)
M = 5; N = 24
ALLOCATE (I(M:N))
I(5)=50; I(6)=60 ; I(21)=210; I(22)=220
I(7)=70; I(8)=80 ; I(23)=230; I(24)=240
END
Thanks very much
Hamid
