29632 Discussions
Display class variable in debugger not work
ZlamalJakub
New Contributor III
I am testing classes and I have problem displaying variables in debugger:
When I enter class function and set variable to some value, in I do not see correct value in debugger
(in this example I suspect this%Var=3).
Is this behavior problem of integration of Fortran in VS or I have something bad configured?
I have IVF 11.1.046 an VS2008 Shell 9.0.21022.8 RTM (Installed with 11.1.035).
Thanks for advice
Jakub
This is a bug reported earlier and fixed for "Update 3", scheduled for late October. The issue ID is DPD200138089.
ZlamalJakub
New Contributor III
I downloaded update 3, recompiled my program and problem with displaying class variable remains
Complied with compiler 11.1.051, tested in visual studio 2008 (I installed only compiler not visual studio).
Was this problem really fixed?
Jakub
Lorri_M_Intel
Quoting - Quba
No, sorry, the exact problem you reported --- unable to display dummy arguments that are class variables -- is not yet fixed.
The one Steve referenced was for non-dummy arguments.
The internal id for the displaying of dummy arguments problem is DPD2000140422
- Lorri
ZlamalJakub
New Contributor III
- Lorri
I tried to look at issue on my premier support but I was not able to display it. Is there possibility to me to look at it even I am not author of issue? If Yes, how?
Jakub
That is not a Premier Support issue number - it's from our internal tracking system. I will add a reply here when that issue is fixed (or perhaps Lorri will.) You can also look at the list of fixes linked from the release notes of each version - the "DPD2" numbers for fixes in each update are shown there (usually!)
Looks like I missed updating this thread - CLASS variables can now be viewed in the debugger.
