DlgModeless freezes application
onkelhotte
New Contributor II
Hi there,
I want to display a dialog box in an QuickWin application. This dialog box contains values for a calculation, that runs in the background. These values can be updated at run time by the user and he sees in other QuickWin windows how these values affects the calculation in certain diagrams/plots/whatever.
Because I cant use multi-threading (not allowed by the customer) and DlgModal doesnt allow backgrounding calculation, I use a DlgModeless Dialog.
And here is my problem: When I open the DialogBox from the program (!call MainDialog() in the code), I only see the frame, no buttons, no text and the application freezes.But, when I insert in the menu the Dialog Subroutine, it is displayed propably, when I select Dialog from the menu.
Does anybody know why this happens? Do I have to initialize s.th. else before calling the main dialog?
Thanks in advance,
OnkelHotte
Code:
	program test
	use dflogm
	use dflib
	implicit none
	include 'resource.fd'
	character*72 string
	logical l
	external MainDialog
	type(dialog) dlg
	type(qwinfo) winfo
	type(windowconfig) wc
	winfo%type = QWin$Max
	l = SetExitQQ (QWin$ExitNoPersist)
	l = SetWSizeQQ(QWin$Framewindow, winfo)
	l = InsertMenuQQ(2, 6, $MenuEnabled , '&Dialog'C, MainDialog)
	l = SetWindowconfig(wc)
	wc%Title = 'Outputwindow'C
	wc%NumXPixels  = 640
	wc%NumYPixels  = 446
!	call MainDialog()
	read*,string !stops until input; normally calculation starts here
	end program test
c *********************************************************************
	subroutine MainDialog
	use dflogm
	implicit none
	integer iret
	logical l
	type(dialog) dlg
	l = DlgInit(IDD_DIALOG_MAIN,dlg)
	iret = DlgModeless(dlg)
	end subroutine MainDialog
onkelhotte
New Contributor II
I found something out, but I dont know what to do about it:
With Spy++ I watched the two dialogs. When I open the dialog through call MainDialog(), Window Proc is unavailable, when I open the dialog through the inserted menu, Window Proc is 77D6E54F. IsWindow Proc the reason why my dialog wont open?
anthonyrichards
New Contributor III
according to the documentation "routine
(Input)
...EXERNAL. Callback subroutine that is called if the menu item is selected. All routines must take a single LOGICAL parameter which indicates whether the menu item is checked or not. ..."
Your callback should have a single argument.
onkelhotte
New Contributor II
Sorry, I dont understand how this helps me... :-/
anthonyrichards
New Contributor III
Change dlgmodeless to DLGMODAL and it works ok.
However,a modeless dialog box requires a message loop, according to the documentation.That's your problem. Change the code to this and it works:
Code:
	subroutine MainDialog(CHECKED)
	use dflogm
	use dfwin
	implicit none
	integer*4 iret, ret
	logical  CHECKED, lret
	type(dialog) dlg
     type (T_MSG)  mesg
	lret = DlgInit(IDD_DIALOG_MAIN,dlg)
	if(lret.eqv. .false.) then
		checked=lret
		return
	endif
    ! Read and process messages until GetMessage returns 0 because
     ! PostQuitMessage has been called
     do while( GetMessage (mesg, NULL, 0, 0) )
        ! Note that DlgIsDlgMessage must be called in order to give
        ! the dialog box first chance at the message.
        if ( DlgIsDlgMessage(mesg) .EQV. .FALSE. ) then
            lret = TranslateMessage( mesg )
            ret  = DispatchMessage( mesg )
        end if
     end do
		CALL DLGUNINIT(dlg)
	CHECKED=.TRUE.
..on second thoughts...having tried the above, and successfully displaying the dialog, I havediscovered that on exiting the application using the system menu close button or the File..Exit menu, on occasion the process is not terminated correctly and remains in memory (visible in the task manager window) even though the Quickwin window vanishes. I would stick with using a modal dialog...
Message Edited by anthonyrichards on 04-27-2005 06:40 AM
onkelhotte
New Contributor II
Thanks, that works!
onkelhotte
New Contributor II
On your Update: I tried File...Exit a few times and the program exited correctly without staying in memory.
Thanks a lot for your help!
Message Edited by OnkelHotte on 04-27-2005 06:58 AM
