29285 Discussions
DllMain@12 already defined in LIBCMTD.lib error
larryscheier
I am trying to link a large mixed C/Fortran project and am getting the following errors: (note: as far as I know, I do not have any routines called DLLMain so it must the the default one)
Linking...
nafxcwd.lib(dllmodul.obj) : error LNK2005: _DllMain@12 already defined in LIBCMTD.lib(dllmain.obj)
nafxcwd.lib(afxmem.obj) : error LNK2005: "void * __cdecl operator new(unsigned int)" (??2@YAPAXI@Z) already defined in LIBCMTD.lib(new.obj)
nafxcwd.lib(afxmem.obj) : error LNK2005: "void __cdecl operator delete(void *)" (??3@YAXPAX@Z) already defined in LIBCMTD.lib(dbgdel.obj)
nafxcwd.lib(dllmodul.obj) : warning LNK4006: _DllMain@12 already defined in LIBCMTD.lib(dllmain.obj); second definition ignored
nafxcwd.lib(afxmem.obj) : warning LNK4006: "void * __cdecl operator new(unsigned int)" (??2@YAPAXI@Z) already defined in LIBCMTD.lib(new.obj); second definition ignored
nafxcwd.lib(afxmem.obj) : warning LNK4006: "void __cdecl operator delete(void *)" (??3@YAXPAX@Z) already defined in LIBCMTD.lib(dbgdel.obj); second definition ignored
Creating library Debug/T700Sim.lib and object Debug/T700Sim.exp
cdsTrace700T700WinV414.dll : fatal error LNK1169: one or more multiply defined symbols found
Error executing link.exe.
Here are my Fortran project settings:
/check:bounds /check:overflow /check:underflow /compile_only /debug:full /include:"Debug/" /dll /math_library:fast /nologo /threads /traceback /warn:argument_checking /warn:declarations /warn:nofileopt /module:"Debug/" /object:"Debug/" /pdbfile:"Debug/DF60.PDB"
Here are my C project settings:
/nologo /MTd /W3 /Gm /GX /ZI /Od /D "WIN32" /D "_DEBUG" /D "_WINDOWS" /D "_MBCS" /D "_USRDLL" /Fp"Debug/T700Win.pch" /YX /Fo"Debug/" /Fd"Debug/" /FD /GZ /c
Here are my linker settings:
/nologo /subsystem:windows /dll /incremental:yes /pdb:"Debug/T700Sim.pdb" /debug /machine:I386 /nodefaultlib:"msvcrt.lib" /out:"cdsTrace700T700WinV414.dll" /implib:"Debug/T700Sim.lib" /pdbtype:sept
Let me know if anyone has an idea to resolve this.
Lawrence Scheier
SEI Associates
ArturGuzik
Valued Contributor I
Lawrence,
I guess this is a Multiple C Library Syndrome. Take a look at this article
http://http://h18009.www1.hp.com/fortran/visual/vfn10/page2.html#Karam
and Steve's reply and useful suggestions in this thread
http://softwareforums.intel.com/ids/board/message?board.id=5&message.id=7805
A.
larryscheier
I don't see a solution from that suggestion. Perhaps if I knew what the nafxcwd.lib
(where the conflicts are arising) was, I'd be able to figure it out.
Larry Scheier
I think that's an MFC library. You may want to try adding libcmtd.lib into the "ignore libraries" list in the linker options.
ArturGuzik
Larry,
it seemsthat the problem lies in the order libraries are linked in your project
(CRT libraryis linked before MFC lib). See this KB article.
Ihope thatthis will solvethe problem.
A.
Message Edited by ArturGuzik on 02-24-2004 07:58 PM
