29376 Discussions
DllMain not being called on loading the DLL under Win32 config
ferrad1
I'm almost done creating a Win32 version of my project which works fine under x64.
The problem I am having at the moment is that the DllMain function in my DLL is not being called when the DLL is being loaded.  It is being called under x64.
Do I have to do something special to get it to be called under Win32?
Steve_Lionel
You have to give it the correct name. On 32-bit, it is a STDCALL routine _DllMain@12 . (Use !DEC$ ATTRIBUTES STDCALL, DLLEXPORT, ALIAS:"_DllMain@12").
ferrad1
That worked, thanks (I added :: DllMain at the end)
!DEC$ ATTRIBUTES STDCALL, DLLEXPORT, ALIAS:"_DllMain@12" :: DllMain
FortranFan
