This do loop example has NO passes thru it.
dk4=100000000
khi4=huge(k4)/2 ! nowhere near upper limit
klo4=-khi4 ! nowhere near lower limit
kount=(khi4-klo4)/dk4+1
print *,"klo,hi=",klo4,khi4," kount 4=",kount
do k4=klo4,khi4,dk4
print *,"k4=",k4
enddo
It gives the correct result (22) for KOUNT, but the compiler apparently gives ZERO for the same thing.
All variables are integer(4)
Looks ok to me. I added IMPLICIT NONE and an explicit default integer declaration for all referenced variables, and:
>ifort /check:all /warn:all /stand /standard-semantics "2015-03-09 do-loop-1.f90" && "2015-03-09 do-loop-1.exe" Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.2.179 Build 201501 21 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. Microsoft (R) Incremental Linker Version 10.00.40219.01 Copyright (C) Microsoft Corporation. All rights reserved. "-out:2015-03-09 do-loop-1.exe" -subsystem:console "2015-03-09 do-loop-1.obj" klo,hi= -1073741823 1073741823 kount 4= 22 k4= -1073741823 k4= -973741823 k4= -873741823 k4= -773741823 k4= -673741823 k4= -573741823 k4= -473741823 k4= -373741823 k4= -273741823 k4= -173741823 k4= -73741823 k4= 26258177 k4= 126258177 k4= 226258177 k4= 326258177 k4= 426258177 k4= 526258177 k4= 626258177 k4= 726258177 k4= 826258177 k4= 926258177 k4= 1026258177
Bill,
I agree with your findings. I thought the loop would be calculated as I have expanded it, but perhaps not. (it may depend on the compiler version.)
integer*4 dk4, khi4, klo4, kount, k4 dk4 = 100000000 khi4 = huge(k4)/2 ! nowhere near upper limit klo4 = -khi4 ! nowhere near lower limit kount = (khi4-klo4)/dk4+1 ! print *,"klo,hi=",klo4,khi4," kount 4=",kount print *,"khi4-klo4", khi4-klo4 ! print *," " print *," test DO loop" do k4 = klo4,khi4,dk4 print *,"k4=",k4 end do print *," exit do k4=",k4 ! print *," " print *," test DO loop calculations" k4 = klo4 do ! k4 = klo4,khi4,dk4 if ( k4 > khi4 ) exit print *,"k4=",k4 k4 = k4 + dk4 end do print *," exit do k4=",k4 ! end
Ok - I see no iterations on the 32 bit platform.
As discussed in the other threads, the calculation of the iteration count is formally stated as the expression (finish - start + step) / step, conducted in the kind of the do variable. If the compiler honours the parentheses (as is usually required by the language rules) then the result of the sub-expression in the parentheses exceeds what an default integer variable can hold - that's a numeric operation that is not defined by the arithmetic used by the processor - non-confoming program - anything can happen.
I have changed my view on this one a bit. If we read the standard on this (which now have!) it is a non-conforming program however it did think it was slightly perverse calculating (finish - start + step) / step which overflows when (finish - start)/step + 1 which does not could be used and would gives a productive loop in the examples cited. However, a few moments thought and we can see the case where start is negative and finish is positive will overflow by the second method in some cases.
In the general cases the iteration count has to be determined at run time and I guess the standard writers picked the form of the calculation to preclude the forced need to evaluate several permutations for every such do loop. I think I will now go away and do something useful!
I think the basic problem is (finish - start + step) / step does cause integer*4 overflow, which is not what was claimed in this thread's title. IMHO, this is basically a bad choice of Integer*4 DO loop subscripts, which was Steve's original warning.
John
We may need to read through the minutes of the standards committee to find out why the count is calculated from (finish - start + step) / step rather than (finish-start)/step (finish-start)/step + 1 or some other mathematically equivalent form which, in certain cases, skirts around integer overflow. To me the following is a plausible reason.
Most DO loops do something useful in addition to executing a specified number of times. Typically, the DO index is used in some expression as a subscript, as a subprogram argument, etc. Therefore, if it can be predetermined that the sequential additions of step to the DO index (as in i = i + step) will cause overflow, it may be considered proper to prevent the DO loop from being entered at all, and accept the inevitable in a graceful way at the earliest possible.
The last value of the DO loop index just prior to exiting the loop can be outside the bounds finish and start. Thus, when step is positive, even if finish is less than HUGE_INT, computing the last value can cause integer overflow.
Well, (finish-start)/step gives too small a value: start = 1, step = 1, finish = 10 would lead to 9 steps, rather than 10.
Thanks, Arjen; typo fixed.
It's kinda interesting that SOME of us get the correct number of iterations when we run it -
while others don't.
But I feel rather strongly that it should be consistent across ALL platforms.
Using integer(8) arithmetic would solve that problem, but then it has to be addressed
again for INTEGER(8) variables. Seems like a lotta guesswork, apparently - - - since the standard does not really address that issue.
Since the standard does not give us explicit warnings about INTEGER OVERFLOW regarding DO LOOPS,
most of would assume that all possible values of START, STOP and STEP would give consistent results for all platforms.
I wonder if we see this problem on 64 bit CPUs ?
Was that "correct" result obtained on a 64 bit machine? I think so -
You are doing 64 bit arithmetic there (implicitly) so you dont get the 32 bit overflow (?).
Hey, John Campbell, how do we know what is "correct?" Can you run that with 8 byte variables?
Of course you have to change STEP to a much larger number to get smaller # of steps. Like = 1x10**18.
As I said in an earlier thread, since the values of the limits and the step size can be determined by formulas, or by data inputs,
we really dont have much control over those, and so cannot reliably predict when there would be problems.
An afterthought ;
Why not use REAL(16) arithmetic to calculate that?
We are always guaranteed to get the correct answer for ANY combination of inputs.
You get a REAL(16) result, which you would round off to get the final number.
NO_STEPS = (real(STOP,16) - real(start,16)+real(step,16))/real(step,16)
Since the compiler supports REAL(16) arithmetic, this should not cause any problems.
Bill,
Why don't you introduce a simple check using double precision arithmetic in this specific "huge" loop of interest to you:
program p
use, intrinsic :: iso_fortran_env, only : i8 => int64, dp => real64
!.. Named constants
integer(i8), parameter :: start = 1
integer(i8), parameter :: finish = huge(1_i8)
integer(i8), parameter :: step = finish/4_i8
!.. Program variables
integer(i8) :: i
loop_h: do i = start, finish, step
print *, " i = ", i
if ((real(i, kind=dp) + real(step, kind=dp)) > real(finish, kind=dp)) exit loop_h
end do loop_h
stop
end program p
i = 1 i = 2305843009213693952 i = 4611686018427387903 i = 6917529027641081854 i = 9223372036854775805 Press any key to continue . . .
Separately, if you can explain what exactly you're trying to do in detail, perhaps readers may have suggestions for you on how to revise your algorithm(s) to avoid such loops altogether and which, as Steve alluded to very early on in this topic, may be the best way to proceed.
Oh sure, there are ways to get around this problem, and that's one of them.
You have to be really careful even when simulating a DO LOOP, since the index can overflow.
Unless we do as you suggest, and avoid using integers, or convert the index to an integer to a REAL
quantity before testing it.
In the cryptography work that I do, you very often get some weird values of the parameters,
and those can be generated by data inputs or formulas.
In you example, try setting the START to -huge(I8).
Does it still work OK?
The suggestion in #12 is valid only for a DO in which the index is increasing; i.e., step is positive.You would have to be sure that this is the case, or add more code to cover "backward" loops.
a more general result would be to properly compute the no of iterations:
NITER = (stop-start)/step + 1 ! You still have to be careful,
! since this can give an overflow, so
! maybe reals should be used instead.
then do this:
INDEX = START
DO ITER=1,NITER
! code here
INDEX=INDEX + STEP
ENDDO
Since you never TEST the index, the problem is avoided.
Yes, I wasn't trying to be comprehensive by any means. And, of course, in the more general situation, one may need quadruple instead of double precision. I'm simply suggesting the onus be on the user (Bill) for such needs rather than the compiler.
Amen!
I thought the count calculation should be "(finish - start + step) / step" , rather than "(finish - start) / step + 1" to allow for zero step do loops.
Hello
Back to Fortran 66 where loops where always entered once and all programmers have to add a test before each loop.
More seriously, what I expect from a loop is that it has to be repeated from start value up to end value with the given step.
The only point to remind is that the counter is incremented before the test with the end value. So in my sense, the maximum end value has to be less or equal to HUGE()-step to avoid overflow.
One should also be mindful of performing loops performing steps who's step value cannot be exactly represented. For example a step of 0.1, which has an infinite repeating binary fraction.
The compiler computes an iteration count before execution. How the compiler advances the loop control variable is unknown (undefined). If the compiler chooses to set the loop control variable to start, then on each iteration advance it by way of += step, then on large loop counts it is highly likely that due to accumulation of round off error, that the loop control variable can deviate substantially from being a multiple of step from the start. A more accurate method would be for the compiler to generate lcv = (start + (iteration-1)*step).
! Never code:
do SimTime = 0.0, 86400.0, .001
! rather code
do iSimTimeIteraton = 0, 8640000
SimTime = .001_8 * iSimTimeIteraton
Jim Dempsey
The DO index variables and the expressions m1,m2,m3 are required to be of scalar integer type in F95 and later. Even in F90 the use of other types in this context was declared obsolescent. Vendors, of course, may continue to allow other types, in particular real types, as an extension.
