Do loop takes no advantage of openMP parallelization
tamborski__matteo
I am willing to parallelize an inner loop with openMP.
The code is similar to the one below: a do loop that runs in parallel and contains a long subroutine here replaced by dummy calculations (the scope of the parallelization would be to parallelize the time-consuming subroutine).
  program main
      use omp_lib
      implicit none
        double precision :: wtime, a, b, c
        double precision, allocatable :: res(:)
        integer ::i, j, i_max, j_max
        i_max = 10000
        allocate(res(i_max))
        call omp_set_num_threads (4)
        wtime = omp_get_wtime ( )
        !$omp parallel default(private) shared(res, i_max)
        !$omp do
        do i = 1, i_max
            ! long subroutine, here replaced by dummy calculations
            a = real(i)
            b = real(i)**2
            c = b**2+a**2
            res(i) = real(c)
        end do
        !$omp end do
        !$omp end parallel
        wtime = omp_get_wtime ( ) - wtime
        print*, 'Elapsed time parallel simulation : ', wtime
        do i = 1, i_max
            a = real(i)
            b = real(i)**2
            c = b**2+a**2
            res(i) = real(c)
        end do
        print*, 'Elapsed time serial simulation   : ', wtime
    end program
What the program prints out is:
Elapsed time parallel simulation :   2.046999987214804E-003
 Elapsed time serial simulation   :   2.710008993744850E-005
That is the opposite of what I'd expect.
For the dummy code the compiler could have taken some shortcut to make sequential code faster, but similar result happens when I run the code with the long subroutine instead of the dummy 'res(i) = c': in this case the parallelization doesn't slow the code that much, but it is still slower or, at best, no gain.
I compiled it with intel fortran compiler using Microsoft VS.
Why is parallelization inefficient in my code? I could not find any documentation (or rules of thumb) on whether a code could gain or not from parallelization. Could be a Microsoft VS project option instead?
I will greatly appreciate your contribution.
Thanks a lot.
Matteo
John_Campbell
New Contributor II
You have a number of problems with this example;
1) omp_get_wtime may not be accurate enough. I use System_Clock with integer*8 arguments to get better precision.
2) your loop does not have enough calculation to offset the OMP region overheads ( ~ 5E-6 seconds ) in comparison to serial loop. It is a common problem of !$OMP trivial examples that they don't demonstrate the basic requirement of !$OMP to improve clock time performance.
3) don't use too much optimisation that trivialises your test loop.
4) I introduced count_id to confirm the expected thread usage.
I modified your example to hopefully vary the loop workload and demonstrate improved performance in some cases. This can vary with processor or compiler optimisation.
  program main
      use omp_lib
      implicit none
        integer :: i, j, i_max, j_max, N, id, count_id(0:11)
        double precision, external :: delta_seconds
        do j = 1,2
          if (j==1) j_max = 1         ! not enough work
          if (j==2) j_max = 10000     ! more work
          DO N = 1,3
            i_max = 10000 * 10**(n-1)
              write (*,*) 'i_max, j_max =',i_max, j_max
            count_id = 0
            wtime = delta_seconds ( )
         !$omp parallel do default(private) shared(res, i_max, count_id)
            do i = 1, i_max
                id = omp_get_thread_num()
                count_id(id) = count_id(id) + 1
                call do_more_work (j_max, a)
                a = real(i)
                b = real(i)**2
                c = b**2+a**2
                res(i) = real(c)
            end do
         !$omp end parallel do
            print*, 'Elapsed time parallel simulation : ', wtime, count_id(0)
            count_id = 0
            do i = 1, i_max
                a = real(i)
                b = real(i)**2
                c = b**2+a**2
                res(i) = real(c)
            end do
            print*, 'Elapsed time serial simulation   : ', wtime, count_id(0)
            deallocate(res)
          END DO ! N
        end do ! j
    end program
   double precision function Delta_Seconds ()
      integer*8        :: clock1 = 0
      integer*8        :: clock2, rate
      double precision :: dt
       CALL SYSTEM_CLOCK (clock2,rate)
       dt = (clock2-clock1)/DBLE(rate)
       clock1 = clock2
       Delta_Seconds = dt
   end function Delta_Seconds
   subroutine do_more_work (j_max, a)
      double precision :: a, b
      integer :: i, j_max
      a = 1.0
      do i = 1,j_max
        b = log(a)
        a = a + b
      end do
   end subroutine do_more_work
John_Campbell
New Contributor II
My apologies, as I did not declare j_max as shared. ( I don't normally use "default(private)" but prefer to declare all variables explicitly as private or shared )
I did some other minor changes to compare the serial and parallel results.
Now, for small i_max,j_max, parallel is slower than serial, but for increased workload with larger i_max, j_max, parallel is faster.
The revised example is:
  program main
      use omp_lib
      implicit none
        double precision :: wtime, a, b, c, so,ss
        do j = 1,2
          if (j==2) j_max = 1000      ! more work, but not too much
          DO N = 1,3
            i_max = 1000 * 10**(n-1)
              write (*,10) 'i_max, j_max = ',i_max, j_max
            count_id = 0
            so = 0
         !$omp parallel do default(private) shared(res, i_max, j_max, count_id) REDUCTION(+ : so)
            do i = 1, i_max
                b = real(i)**2
                c = sqrt(b)+a**2
                res(i) = real(c)
                so = so + c
            end do
            write (*,11) 'Elapsed time parallel simulation : ', wtime, count_id(0), so  ! report sum
            count_id = 0
            ss = 0
            do i = 1, i_max
                b = real(i)**2
                c = sqrt(b)+a**2
                res(i) = real(c)
                ss = ss + c
            end do
            write (*,11) 'Elapsed time serial simulation   : ', wtime, count_id(0), ss, so-ss  ! compare sums
            deallocate(res)
          END DO ! N
        end do ! j
    10 format (/a,i0,1x,i0)
    11 format (a,f10.6,1x,i8,2es12.4)
    end program
       clock1 = clock2
       Delta_Seconds = dt
      integer :: i, j_max
      a = 1.1            ! b now varies through loop
      do i = 1,j_max
        b = log(a)
        a = a + b
      end do
      a = b
