Documentation: colorization of extensions to the Fortran standard
Paul_M_5
I recently upgraded ifort to version 17.
In the new HTML documentation (especially in the "Language Reference" chapter), extensions to the Fortran standard can no longer be distinguished, as in the previous version, with the help of the text color.
This regression affects both the files installed on the local hard drive and the online documentation.
For example, the color of the text describing the ABORT procedure is green version 16:
      https://software.intel.com/en-us/node/692509
This highlighting disappeared in version 17:
      https://software.intel.com/en-us/node/678983
However, the highlighting of extensions is still present in the documentation in PDF format, for example on the page 1175 of the following document:
      https://software.intel.com/en-us/intel-fortran-compiler-17.0-user-and-reference-guide-pdf
      https://software.intel.com/sites/default/files/managed/93/88/PDF Fortran Compiler UG 17.0=1=SSG 2.0 PDF=en-US.pdf
mecej4
This topic was discussed about a month ago: see https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/625081 .
