Documentation index in Start Menu
Jugoslav_Dujic
Valued Contributor II
Why only Intel Fortran has the peculiar idea that the documentation should be reachable through a .html page, accessible from the start menu? The idea is very bad: I expect to have the pdf or chm or whatever accessible through one mouse click. Instead, I must go through hoops to reach it. Here's one scenario:
1) I click on "Documentation" in the start menu. If not already open, my Firefox is set up to remember the last session so I have to wait 5-10 seconds for it to complete.
2) Say I need MKL documentation. On the web page (filled with wall of unnecessary text, half of which is the legal disclaimer), I have to locate & click on "Intel Math Kernel Library Documentation" link
3) A new tab opens, with the same wall of text. I'd like to open "mklman.chm"...
4) However, it is a chm, and Windows has Security (you know, the stuff that lets hackers in but prevents you from doing the job), so I get only the choice of "save file" but not "open" it. In resignation, I copy the shortcut into the Explorer Address Bar and I finally get my help.
That's only a dozen or less .pdf or .chm items, and they all should be simply available from the Start Menu. Please, save us from all those hoops.
bmchenry
New Contributor II
How i use it is toopen it and leave it open. Then subsequent access is instantaneous.
It's thesame as with MSDN Library documentation.
The documentation people tell me that the preferred way of opening the documentation is from within Visual Studio.
Jugoslav_Dujic
I see. I didn't know that MKL documentation is embedded with the rest.
However, speaking of MKL, an important piece is missing (as far as I can tell): an equivalent of userguide.pdf. In particular, its chapter 3 and the page "Layered Model Concept" is extremely important in order to get the linked MKL libraries right, but I don't see that information anywhere in the rest of the online help. For example, searching for "mkl_intel_thread.lib" in the online docs gives a plenty of false hits but I don't see it actually mentioned anywhere.
Jugoslav,
Please make your comments known in the MKL section of the forum so that the MKL developers can understand the issue. Thanks.
Jugoslav_Dujic
rase
The randomly inserted spaces are really a nuisance. Please get rid of that problem ASAP.
I am told that the spaces issue should be fixed shortly.
