In the compiler manual for ATTRIBUTES DEFAULT, it doesn't indicate where in the program (or subprogram) this clause is required to be located (or if it even has such a requirement). Scanning through the Intel-supplied f90 files in compiler/latest/linux/compiler/include, it appears as though they are inside the interface block, and specifically inside the subprogram definition block they are modifying. But is this a requirement for proper operation? A quick test seems to suggest it is not, but it would be nice if the placement of this directive were called out explicitly in the reference manual. Thanks!
P.S. -- Thanks for the library; the Intel-optimized routines run laps around my generic implementations of them.
To quote Dr Fortran "The purpose of DEFAULT is to prevent switches such as /iface from having an effect. With DEFAULT in the list, none of the characteristics can be changed by compiler switches."
