29343 Discussions
Documentation question: ATTRIBUTES DEFAULT placement
ereisch
New Contributor II
In the compiler manual for ATTRIBUTES DEFAULT, it doesn't indicate where in the program (or subprogram) this clause is required to be located (or if it even has such a requirement).  Scanning through the Intel-supplied f90 files in compiler/latest/linux/compiler/include, it appears as though they are inside the interface block, and specifically inside the subprogram definition block they are modifying.  But is this a requirement for proper operation?  A quick test seems to suggest it is not, but it would be nice if the placement of this directive were called out explicitly in the reference manual.  Thanks!
P.S. -- Thanks for the library; the Intel-optimized routines run laps around my generic implementations of them.
andrew_4619
To quote Dr Fortran "The purpose of DEFAULT is to prevent switches such as /iface from having an effect. With DEFAULT in the list, none of the characteristics can be changed by compiler switches."
