29657 Discussions
Does Static Library need to export functions?
Kipling__Michael
I have inherited a VS 2005 solution which contains a C dll project and a Fortran static library project.  The C dll project requires the Fortran routines.  I have updated the solution for VS2010.
The C dll project has the Fortran library added as an Additional Dependency.  I have also added the Fortran library to C dll project.
However, the C project build show unresolved symbols for each of the Fortran routines.
If I add !DEC$ ATTRIBUTES DLLEXPORT to the Fortran routines, then I get no complaints.
Do I really need to export the routines from a static library, or have I missing something?
Regards, Mike
My guess is that your description doesn't quite match what you actually have. DLLEXPORT is only needed if you are linking against a DLL. If the Fortran project really is a static library, that wouldn't be needed.
Can you attach a ZIP of the buildlog.htm from the Fortran project and the build log from the C project?
Kipling__Michael
I have attached log files for both projects.  The C dll project does not build successfully, so the log file for it is a text file.
Mike
Kipling__Michael
I just had a thought. Could it be that C is looking for lowercase function names, but the static library lists them with uppercase?  If so, is there a option to write the symbol names in lowercase?
Mike
Yes, case matters. Also, I see you are using STDCALL, which Intel Fortran doesn't use by default. Is that deliberate? I don't see the Fortran library build log.
