29488 Discussions
Does this error make sense? Intel_SSA
DavidWhite
Valued Contributor II
Does the way Intel_SSA reports this make sense in a Fortran context? STREAM_ID is not size (1:9) nor is there an index 0:
CHARACTER(LEN=10) :: STREAM_ID
STREAM_ID=" "
ID  Type Sources  State Weight Category
P1  Bounds violation Write_Multi.f90  New 100 Buffer overflow
Write_Multi.f90(184): error #12048: buffer overflow: array index of "STREAM_ID" is outside the bounds; array "STREAM_ID" of size (1:9) is indexed by value 0
thanks
David
No, this is a SA bug already reported.
DavidWhite
Steve
Is SA actually a useable tool for Fortran? The number of false reports makes me think I am wasting my time using it.
e.g.
P12: Error: Unreachable statement
Spl3.f90(92): error #12192: unreachable statement
  X6: Unreachable code: C:\Open\kwc54dw\Dev\Winyldmd\trunk\ymd_main\Spl3.f90(92): Function SPL
  Code snippet:
   90      IF (SPLIT1==0D0) SPLIT1=1D0-SPLIT2
   91      IF (SPLIT1==0D0) SPLIT1=1D0
  >92      TSPLIT=SPLIT1+SPLIT2
David
I find SA a sometimes-useful tool for Fortran. You do have to weed through a lot of false positives. I wish it were better, but I don't see that happening any time soon. That said, if you can put up with its noise, it can help you find problems you'd miss otherwise.
