Double precision declares
micromuni
I am using Intel Fortran 7.0 and encounter the following:
I define the variable d1 to have the following value:
double precision d1
d1 = 123456789.123
In both the calling routine (in VB.Net) and the Fortran routine in Intel Fortran 7.0, the variable is declared as double precision. However the returned value is
123,456,792.00
When I declare the variable in Intel Fortran 7.0 as:
double precision d1
d1 = 123456789.123d0
the answer returns correctly as 123,456,789.12
This has got to be happening on the fortran side. Any comments as to what I am missing (other than the d0 extension)? Is this 'd0' extension always required for constants?
You already figured it out. Without the D0 (or _8), your constant is, by definition in the language, "default real" (single precision). So the value first gets converted to single precision, then extended with binary zeroes to double precision - not what you want.
Using D0 is the simplest and most portable method. But modern Fortran programmers usually define a series of "kind" constants, such as:
INTEGER, PARAMETER :: K8 = KIND(1.0D0)
and then write 123456789.123_K8
The reason for doing it this way is that specific kind numbers are implementation-dependent.
I suggest for further reading the set of articles "The Perils of Real Numbers" that you can find in back issues of the Visual Fortran Newsletter.
Steve
