29340 Discussions
Downloadable file (Intel Fortran Composer EX 2011) is not unpacked, could you let me know how to do..
Anonymous21
Downloadable file is not unpacked, could you let me know how to do?
This is my computer situation as follows,
[root@david intel_fortran]# ls
l_fcompxe_2011.4.191.tgz
[root@david intel_fortran]# tar -xzvf l_fcompxe_2011.4.191.tgz
l_fcompxe_2011.4.191/
l_fcompxe_2011.4.191/rpms/
l_fcompxe_2011.4.191/rpms/EULA.txt
l_fcompxe_2011.4.191/rpms/intel-compilerpro-common-191-12.0-4.noarch.rpm
l_fcompxe_2011.4.191/rpms/intel-compilerpro-devel-191-12.0-4.i486.rpm
gzip: stdin: invalid compressed data--format violated
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
l_fcompxe_2011.4.191 l_fcompxe_2011.4.191.tgz
Question:
--> manualsays"tar -xzvf name-of-downloaded-file"
Ihave a questionwhether this option in order to unpack is correct or not.
Could you let me knowhow tounpack? Is there any option andcommand to unzip??
David
Kevin_D_Intel
The command cited to unpack the file is correct. It appears the downloaded file may be corrupted. Please download the file again and unpack using the command you cited.
Be sure to remove the l_fcompxe_2011.4.191 directory before re-trying the unpack.
Kevin_D_Intel
Anonymous21
Thanks for your reply. Therefore, I solved my problem..
mecej4
It is possible to check whether the downloaded file is complete and uncorrupted. After downloading, you can compare the size and the checksum to those posted at Intel Composer XE 2011 Checksums. Doing may save you time if you can pin down the cause of the failure as a problem with the download rather than something else in your system.
