Dynamic DLL Loading
Ilie__Daniel
Hello!
I have a cosole program written in Fortran and I want to dynamically load a DLL, which can be written by a thrid party. The problem is that the DLL can be written in C++ or Fortran. The headers to the routines in the DLL are preset. What flags have to be specified in the DLL:
  1. on the DLLEXPORT line? (pressumably something like ATTRIBUTES DLLEXPORT, ALIAS:"USERFUNC" :: USERFUNC)
  2. on the argument declaration lines? (REFERENCE or VALUE)
so that the routines in the DLL can interface with the main Fortran program. What attributes should I include so that the correct routine names are exported to my Fortran application? I use the /iface:CVF for all my files.
On a side issue:
As I understand, variables in Fortran are passed by reference rather than by value. Correct me if I'm wrong! If you take the following pseudo-code:
program main
i=0
call sub(i)
print*,"i=",i
end program
sub(j)
j=j+1
print*,"j=",j
end sub
If variables are passed by reference then the output is: j=1, i=1.
If variables are passed by value, then the output is: j=1, i=0.
Am I getting this right?
Thanks and regards,
Daniel.
If you are using /iface:cvf, then your C++ code will need to use __stdcall in the prototype for the Fortran routine. You may not need to add an ALIAS - how is the routine declared in C++?
Yes, pass by reference is the default. This can change if you use certain attributes such as C or STDCALL in directives. You can also specify VALUE on a !DEC$ ATTRIBUTES directive for the argument, or can use the Fortran 2003 VALUE attribute. The difference is that with !DEC$ ATTRIBUTES VALUE you cannot modify the argument inside the routine, whereas with the F2003 VALUE you can but are modifying a temporary copy that is discarded on exit.
Ilie__Daniel
The routine is exported as __stdcall (void EXPORT __stdcall func1(double&arg) ).
Ok. In that case the directive you'll want is this:
!DEC$ ATTRIBUTES DLLEXPORT, STDCALL, REFERENCE :: func1
This will apply the correct name case (lowercase) and decoration and also specify pass-by-reference.
Ilie__Daniel
One more thing, Steve: Is it mandatory to specify thedirective in uppercase?
Les_Neilson
Valued Contributor II
Quoting - Daniel I.
No. It's just a style thing - it stands out in the code better.
Les
