29487 Discussions
How do I force the 64bit ifort compiler to use x87 FPU and not SSE2?
Henrik_S_
How can I force the 64 bit ifort compiler to generate x87 FPU code (internal 80 bit precision) instead of SSE2 (internal 64 bit precision)? As best as I can tell, the 32bit compiler by default uses the x87 FPU unless an architecture flag is passed. The 64 bit compiler use -xW by default which forces SSE2 (I think). How can I tell the compiler to generate x87 FPU code?
This is for benchmarking and testing purposes.
- Henrik
I'm not sure what the point of this is - you deliberately want to hobble the code? Note that in version 11, SSE2 will be the default for IA-32 as well. You would be better off to tell the 32-bit compiler to assume SSE2 (-xW) if you want a real comparison.
From a glance through the compiler options manual, I don't see an option to do this. I'm not even sure the compiler has support for that. -mia32 is not supported in the x64 compiler.
TimP
ifort -O1 -mp appears to have the requested effect. I don't know if this is intentional.
TimP
You may have to call a C function to reset to 64-bit precision mode, if -pc80 (for compilation of the main program) doesn't do it. Either gcc or icc, can use facilities to avoid direct use of inline asm.
TimP
ifort -fno-inline-functions -ftz- -assume protect_parens paranoia.f
./a.out>ifortnftz.out
ifort -fno-inline-functions -mp paranoia.f
./a.out>ifortmp.out
diff ifortnftz.out ifortmp.out|less
< SUBEXPRESSIONS DO NOT APPEAR TO BE CALCULATED
< WITH EXTRA PRECISION
> SOME SUBEXPRESSIONS APPEAR TO BE CALCULATED EXTRA-PRECISELY
> WITH ABOUT 11.000000 EXTRA BASE B DIGITS, I. E.
> ROUGHLY 3.3113298 EXTRA SIGNIFICANT DECIMALS.
> THAT FEATURE IS NOT TESTED FURTHER BY THIS PROGRAM.
Similar to gfortran -mfpmath=387 result
Henrik_S_
Thank you everyone!
- Henrik
